Home > Technical (L322) > What size driver do i need on front suspension
koffeetemple
Australia 2009 Range Rover Autobiography TDV8 Zambezi Silver
Hi Folks Smile
I am going to replace my front air suspension on my 2009 L322 Vogue
As i have the brembo brakes there is a extra damper on the airbag as seen in the attachment. Can anyone tell me what size Torx or Hex driver fits the top of the damper to tighten it
Thanks for your help
Damien Very Happy
[img]http://www.fullfatrr.com/gallery/albums/userpics/16609/damper%20image.pdf[/img]
Post #434705 12th Apr 2017 12:35pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I think it's 14mm on mine but would need to check to be sure.
Post #434706 12th Apr 2017 12:38pm
Tg87
Any ideas how to get the bastard off? It just seems to spin when turned?
Post #516794 28th May 2019 6:58pm
There is a thread on here about this somewhere. It is stuck on with adhesive and requires a serious amount of heat then force to release/remove it .
Post #516823 28th May 2019 10:09pm
Tg87
Thanks I’ll try some more searching. I’ll pop down to the local garage and ask them to give it a go with a torch and bigger rattle gun! Does it serve much of a purpose? Is it worth putting it back on?
Post #516828 29th May 2019 3:54am
TJH1985
https://www.fullfatrr.com/forum/topic47064-15.html
Mine screwed off by hand with heat, after struggling with it. I believe the workshop manual suggests they shouldn’t be reused Rolling Eyes
I think you end up with noisy brakes if it’s no refitted.
Post #516829 29th May 2019 4:56am
Tg87
Thanks for that guys.
With the liberal application of heat and an impact gun it’s off! No need for the garage this time!
Post #516839 29th May 2019 9:02am
