Home > Technical (L322) > "Restricted Performance" error message |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
TBH that is the one which goes, replace to top 2 and you should be good. Not really heard of the bottom ones failing. Wouldn't bother with the garage. Get those 2 on order and get spannering. If the message is still there, which I doubt, then get the garage to fault find and do the bottom ones. There is nothing that can't be fixed with a hammer😜😜
1st Apr 2017 12:22pm |
KRV24 Member Since: 02 May 2016 Location: Berkshire Posts: 35 |
Thanks mate, sound advice. Assume don't need any additional sealant when putting these on?
1st Apr 2017 12:32pm |
No sealant needed just the jubilee clips There is nothing that can't be fixed with a hammer😜😜
1st Apr 2017 2:36pm |
Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50 |
I had the restricted performance issue come up on mine, when I put my diagnostic on I was getting very little air flow over one of the MAF sensors, I thought it was duff and bought another but it made no difference, this unfortunately meant I had a sticking egr valve. after getting this replaced all was good.
10th Apr 2017 9:24pm |
The egr valve issue came and went some 15k miles ago. Both were replaced so was fairly confident that couldn't be it. The Indy did immediately point to that over the phone when I rang for some advice and book a diagnostic.
13th Apr 2017 5:56pm |
Haydn Member Since: 10 Oct 2016 Location: Sussex Posts: 10 |
oooo you lovely range rover people I was getting the reduced power issue went to Reading today about 70mls, 140 round trip and happened twice on the way there and 3 times on the way back I found when I used cruise control on the motorway it happened more as with pedal control I could feel it stuttering and eased off which helped to prevent limp mode
21st May 2017 5:51pm |
