![]() | Home > Technical (L322) > Issue when starting car when it's hot ! (FIXED PAGE 2) |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
Hi,
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1808 ![]() ![]() |
Could also be an injector. As it heats up and the internals expand, it causes excessive leak off when cranking |
did read somewhere about someone having same kind of issues and was leaking injector so when stopping fuel was leaking into cylinder and sitting there so car was little flooded when starting each time.
Sensors I have ordered are arriving Monday apparently. As crank sensor was a not in stock item.
Update,
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
.double post |
I had the very same issue a few weeks back and it stopped instantly once I changed the petrol filter.. car would start great then after a run it would start then cut out or threaten to cut out |
Hi thanks for the reply
checked to see if coolant sensor's are working and they are.
last update,
Jacckk Member Since: 31 Dec 2015 Location: Durham Posts: 18 ![]() ![]() |
I've also got the same issue so it would be good to know if you solve it.
I just replaced the pump inside the assembly, I have see some posts about a non return valve but to be honest at the time I did not fully take notice to see if that's the case.
so, Replaced fuel injectors with refurbish ones.. still same issue... must admit losing my patience now..
swapped fuel filter back to old one, to make sure the pressure regulator was working correctly same issue. Although car now actually losing fuel pressure it seems now, when i leave for 30mins or hour fuel pressure is very low.. Cannot see any fuel leaks of anykind.. Issue is i have replaced. New fuel pump (just motor Replaced) New fuel filter New Crank Sensor 2x New Cam Sensors New Set Injectors. Same Issue.. there's nothing else left to cause any issues is there ? Does anyone know if theres a check valve on the fuel pump or pump Assembly ? 2003 Range Rover 4.4 Litre V8 - Adriatic blue 2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 ![]() ![]() ![]() |
Sorry to hear it's not sorted yet |
