Home > Wheels & Tyres > Space Saver after move from 255/50 to 255/55?
awclymm
I've just taken the plunge to change all of my tyres on a 2012 Westminster from 255/50/20 to 255/55/20
I've just realised that I need to give some thought to the space saver spare tyre - it's currently a 175/80/19, which I assume won't be healthy to fit alongside the 255/55's if necessary.
Does anybody have any comment on this issue please?
Thanks. 2017 4.4 SDV8 Autobiography
Post #434286 8th Apr 2017 6:07pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I still have a 255/50 as a spare even though I now have 255/55's fitted.
I was told all the diffs are open (unlocked) in road use so as a get you home measure the odd size would not damage the car.
Having said that if I found a decent Michelin Diamaris sport 255/55 I would fit it to the spare because someone on here commented that the larger size still fits the spare wheel well and I'd like them all to match.
But as an emergency measure I'd guess your current space saver is good enough to get out of trouble. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #434318 9th Apr 2017 7:24am
awclymm
That's greeat news! Thanks. 2017 4.4 SDV8 Autobiography
Post #434321 9th Apr 2017 7:54am
Goldy
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I have just got round to swapping my spare tyre to match the 55s on the rest of the car as I was changing the tyres anyway and had a legal part worn as spare.
I have found its a pretty tight fit getting the spare back in. So much so the flooring to the boot as slightly raised.
Only messed about for 5 minutes trying to get it in as I had to go out.
I will need to try again but would be good to know if anyone has had success in fitting the larger tyre spare?
Post #434699 12th Apr 2017 10:54am
