Home > Technical (L322) > Rumble from rear passenger side under hard acceleration |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 584 |
Sounds like you've left the mother-in-law in there by mistake....
4th Apr 2017 2:36pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Turns out it's the rear propshaft centre bearing knackered, got a second hand propshaft on the way and will get it fitted next week.
8th Apr 2017 1:45pm |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 |
Sorry to hijack the thread but I also suspect my centre bearing.
8th Apr 2017 4:51pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
8th Apr 2017 6:29pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
The centre propshaft bearing is available separately.
8th Apr 2017 7:23pm |
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 |
Had one fail on my 3 series BMW IIRC they are about £40ish, not difficult to do just a PITA having to take all the bits off to get to it. 2004 4.4V8 Vogue
8th Apr 2017 11:15pm |
Yes you can just get the bearing on its own, but as said it's a pita to strip down the propshaft to get to the bearing. I've managed to get a good second-hand propshaft with centre bearing for just £85-00, so will cost less in the long run for the garage to replace it, and I'll get the car back on the road sooner.
10th Apr 2017 11:34am |
Does anyone have or know of a how to for stripping the prop shaft? |
10th Apr 2017 7:58pm |
The strip down of the propshaft and bearing is covered in the Workshop Service Procedures Manual, have a look in the Wiki section for the manual.
10th Apr 2017 10:06pm |
Well, picked up the Rangie today and my mechanic showed me the old propshaft. The universal joint was in a pretty poor state with one of the pins pretty badly damaged. It was darned lucky that I had got a replacement second hand propshaft and centre bearing, otherwise I would have been stuck.
14th Apr 2017 5:43pm |
Thanks for the info Dt.
14th Apr 2017 7:05pm |
