Home > Maintenance & Mods (L322) > Replacing pads and disks
Iant75
I am looking to replace the pads and disks on my 2008 FF.
I have been told it a straight forward enough job, but rear handbrake adjustment can be tricky. anyone have and tips or advice before I try this?
Any recommendations for where to source the parts?
Iant
Post #433469 1st Apr 2017 3:20pm
workshop manual link in the wiki, parts from our site sponsor duckworths who have a dedicated section .... ... - .- -.
Post #433472 1st Apr 2017 3:27pm
All fairly simple spannering,
There are a few things to do while you are at it with bits off
1 use a file to clean out where the pads sit in the rear caliper carrier, which stops the pads binding in the carrier and overheating the rear discs.
2 check the seals in the brembos on the front for condition
3 run the adjustment cycle for the EPB once you have refitted the new shoes and discs even if just discs.
4 make sure you clean the front hub thoroughly before refitting the discs so he new discs fit flush
5 recommend genuine discs and pads for least problems
6 don't overtighten the bolts on the brembos they are aluminium calipers
If when you are removing one of the bolts from the Brembos it doesn't free up as you are slackening it, you have got a it seized in, this will strip most of the thread out of the calliper. There isn't much you can do about it to prevent it, it's a case of finding someone who can helicoil it for you or getting a new calliper.
Just a few things to be aware of. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #433476 1st Apr 2017 3:41pm
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Carparts4less.co.uk
They stock a variety of makes...I chose Eicher disks and Brembo pads...very impressed.
Make sure you Google discount codes for a further 10-15% off...
Post #433847 4th Apr 2017 6:40pm
