Home > In Car Electronics (L322) > digital lcd tft instrument cluster display
deadcats111
i have a RR VOGUE 4.4 TDV8 on a 2012
when i go to put the ignition on... my LCD / TFT instrument display is flickering on and off quickly???
any ideas? cheers
dtc codes ipc p0607-4b p060a-08 has anyone had this before?
Post #433164 29th Mar 2017 11:20pm
JWL
Hi,
Did you ever get to the bottom of this error? I have similar (with the same fault codes) on a MY2011 and have been advised to swap the entire instrument cluster.
thanks,
James
Post #448825 23rd Aug 2017 1:49pm
deadcats111
Hi mate. We got the problem, it turned out to be the instrument cluster had totally failed. had to buy a brand new one, but you will have to send to main dealer to have done. Make sure you keep the old unit or you will have to buy a new engine ecu and BCM body control module as well to tie in the mileage which by the way is security protected. any problems please ask. cheers
Post #448829 23rd Aug 2017 2:40pm
JWL
Ouch - that is not what I wanted to hear! Can I ask how much it cost please; I have been quoted just over £1,500 and want to understand if that is competitive?
Post #448838 23rd Aug 2017 4:22pm
deadcats111
yep
Post #448845 23rd Aug 2017 6:17pm
Sllimydna
Wales 2010 Range Rover Vogue SE TDV8 Santorini Black
I had exactly the same issue, I also had the display not appear for around 5 minutes after ignition was turned on. Turned out to be a failing alternator. Now I've had the alternator replaced I haven't had any issues whatsoever. Its just a suggestion to get it checked out as its a damn site cheeper than a new or refurbed TFT
Post #477590 5th May 2018 8:45pm
