![]() | Home > Maintenance & Mods (L322) > Interior LED upgrade debacle |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
that happened to me when i changed the door ones...pulled a fuse, fuse ok ,can't remember which one, left it for a while and all was ok..(with leds) ... - .- -.
bluebattery Member Since: 04 Apr 2016 Location: London Posts: 21 ![]() ![]() ![]() |
Interesting Stan. Any thoughts on the suspension fault which seemed to coincide with me putting the bulb in. |
no idea sorry, you could try a battery disconnection to see if that clears it... ... - .- -.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
The interior bulbs won't throw a fault as they aren't part of the canbus system. Exterior will as they are monitored. I can't see how they would affect the eas system tbh? I found my first batch would flicker, replaced the flickering led then instantly the next door led would do the same then the process would repeat.. ended up being poor quality leds. Once I replaced them everything was good..definitely worth double checking the fuse. |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 ![]() ![]() ![]() |
I replaced all my bulbs on my former L322 with LEDs and had no prob at all. All my spelling errorz are belong to me!
Going mad now. Replaced all leds back to candles to see if that would brings the interior lamps back on. Ripped the interior lamp fuse out to reset and see if that does it. Pulled the battery out to see if it would help. Despite all of this - the interior lamps don't light up and to top it all, the car is sticking its fingers up to me with a suspension fault message which seemed to appear the minute i put the leds in.
MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81 ![]() ![]() ![]() |
Tried locking and leaving the car alone for a few minutes before trying the interior lights again ? |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Try a battery disconnect, as when I did mine, the boot lights went out altogether. So I did battery disconnect, and all was well.
Haven't tried locking unlocking. Will give it a go now.
No joy with the lights after code reset using a diagnostics reader. Also tried lock unlock cycles.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
I had the suspension fault issue when changing the dome lights. The interior lights stopped working and the fuse was fine. I just locked the car and left it for a few hours and it seemed to reset itself with everything working fine. Weird but does not surprise me with LR electronics being what they are. Tom
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
A couple of notes that may help you with your install:
