Home > Technical (L322) > Seat belt chime no chime and seat belt light goes out
^ that method worked on my 2012.... ... - .- -.
Post #432398 24th Mar 2017 9:02am
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
My 2006 has never made a sound, light comes on with the ignition and then goes off after starting as normal, don't see anything unplugged so I just assumed it had been somehow disabled by the previous owner.
Flipping airbag light comes on when someone sits in the passengers seat though, but goes off again after it's been cycled a few times, really should look at it.
Post #432433 24th Mar 2017 2:43pm
that will be the occupancy sensor in the seat...mine went and it was a seat out and prising the leather away to replace.. ... - .- -.
Post #432446 24th Mar 2017 4:05pm
hamlet
Thanks Stan, I'm read that you have had the same problem and replaced one of these before in the past.
I'm thinking of swapping my seat covers over, (wear and damage on the drivers side) so might do the whole lot in one go, cheers.
Post #432456 24th Mar 2017 4:46pm
sounds like a plan sir. Thumbs Up ... - .- -.
Post #432457 24th Mar 2017 4:49pm
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
My 2005 has never chimed and the light stays off...
Post #432460 24th Mar 2017 5:01pm
Weegie
AFAIK the chimes were on late vehicles - 2007 onwards (open to correction on exact date). To activate/deactivate use the plug/unplug x times method.
Earlier vehicles would only have had them depending on the market the car was originally specified for. John
GAP iiD BT-Sold
Post #432470 24th Mar 2017 5:45pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi John,
That's what I thought as I have an electronic version of the US handbook and it mentions the chime for my model year (2004) but I managed to dig out the physical UK handbook and it just says dependent on market.
As far as I'm aware the UK were never meant to have a chime for seatbelt use, just as we don't need to be reminded that objects in your mirror blah blah.. Whistle
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #432472 24th Mar 2017 5:56pm
Louismacrides
United Kingdom 2004 Range Rover Vogue SE 4.4 V8 Epsom Green
Thanks all ,looks like they don't chime pre 2005 in uk
Post #432519 24th Mar 2017 9:28pm
northernmonkeyjones wrote:
Sit in car
Close door
Push ignition button without foot on brake
Put buckle into receiver 9 (maybe 10) times within 30 secs
On the final time you will hear a bong
Job done
Brill thanks. Was nine times in my case. Nice to avoid the wrath of the chimes while on our driveway!
FWIW neither my 02 nor facelift SC (06 but 07MY) made any seatbelt noise...... Mike - MPx
Post #432565 25th Mar 2017 10:17am
