![]() | Home > For Sale & Wanted > [sold] Genuine LR towbar bike carrier |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Genuine Land Rover L322 bike carrier.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3226 ![]() ![]() ![]() |
Nice looking car! |
LOL |
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
Just had a read of the instructions. Would I be right in thinking this doesn't fit the factory detachable towbar system? 2004 Vogue TD6 - Remapped |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1404 ![]() ![]() ![]() |
It uses the same armature. You have to undo the bolt holding the towbar in place (not easy as they are assembled dry and at high torque) and then pull out the towbar unit from the armature (may require hammering as they rust into the socket). The bicycle carrier base then bolts into the armature in its place, the spanner required is meant to be included in the LR accessory kit. I'd grease the stem of the bicycle carrier and towbar before putting them back, and copper grease the threads of the bolts on both, to ease changeovers. Only Range Rovers since 1988 |
CS is spot on, it fits into the armature on the towbar |
SOLD
