Home > Maintenance & Mods (L322) > Rear brake pads/shoes and jacking
Jupiterrover
United States 2006 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
2006 RR SUPERCHARGED 4.2
About to install new brake pads and parking brake shoes, I have completed all the how too research. Need a little guidance on the jacking so I can rotate the rear wheels.
Does the truck have to be in neutral to be able to turn the rear wheels while jacked? I assume both wheel have to be lifted?
I have four 6 ton jack stands and 3.5 ton floor jack. I was going to set truck in off road height. Jack each side of truck just before wheels lift off ground and place two stands on either side. Come back to rear lower control arms with floor jack and lift rear wheels off ground. Does this sound right?
Post #432144 22nd Mar 2017 8:46pm
rar110
Leaving 2 wheels on the ground will make the car more stable.
I don't think you can remove the keys unless it's in park. ______________________________
Post #432149 22nd Mar 2017 8:58pm
Chock front wheels both sides
Normal Height
Trolley Jack under lower wishbone
Axle stand under jacking point, take some weight if wheel still off the ground
Wheel off
Take the weight on the axle stand
Repeat other side
Key in, foot on brake, select neutral, handbrake off Wink .
Post #432164 22nd Mar 2017 10:13pm
Jupiterrover
Thanks, are you saying that I can lift one corner at a time and the wheel would still spin even if other side is on ground if in neutral?
Post #432181 23rd Mar 2017 12:23am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
That's why there is a differential - to let the wheels turn at different speeds - in your case an extreme of one not turning at all
Post #432218 23rd Mar 2017 10:16am
miggit
Whistle But You'll need to be feeling strong if you're going to try spinning with just one wheel off the ground, there is a lot of resistance Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #432241 23rd Mar 2017 1:25pm
steptoe
Not much resistance when turning the rear wheels at all. Fitted new rear discs to mine only last week.
Post #432243 23rd Mar 2017 1:44pm
