Home > Maintenance & Mods (L322) > Drivers seat mot failure
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Never heard of this before, but my ff failed the mot today on drivers seat electric switch failure. It also failed with worn offside track rod end and lower suspension arm so it wouldn't have made any difference, but I have been waiting for the warmer weather (not having a garage) to sort it. Unfortunately I wasn't able to check the fuse as I couldn't get in the glovebox (another better weather job) as the first step to checking the supply, but the mech managed to open it and the supply checked out. I have asked the garage to cost a new switch pack (it is the full-on 3 memory 10(12?) way all singing all dancing one going for about £150 second hand on the 'bay) and was somewhat surprised when they quoted £212 new, special order from a LR main dealer. I have asked them to double check as I am aware that there are other seat/fewer switches modules and they have said they double checked so for 60is pound more I think I will go with the new one. QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #431967 21st Mar 2017 7:49pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
My P38 would blow the seat fuse every time you sat on the driver seat. I could hear the fuse ping when I lowered my ample frame onto the seat. Clearly a heated seat wire in there shorting on the seat frame somewhere.
That too failed the mot for a non adjustable driver's seat. I guess the reasoning is that if it cannot be adjusted, you need to compromise your seating position which is potentially unsafe.
The P38 is long gone though (thankfully) 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #431972 21st Mar 2017 8:05pm
Spelunker
Being the sole user of the car (my wife could, but wont drive 'the beast' and with the seat failing when it was in the correct position I never considered it might be a problem. I have not had a car with electrically adjust seats before so I wasn't aware of the mot possibilities... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #431977 21st Mar 2017 8:23pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
interesting read, don't really see why it would be a MOT fail the seat is set for the driver not the MOT tester, there should be no reason for them to even test it I have just checked UKMOT website and it's correct it is a fail
however with all part's of the MOT if it's fitted it has to work, if it's not fitted it don't get tested cover the switch's with a butter tub so nothing can bee seen therefore can't fail....
equally press the 3 memory button's see if there is any movement at all, I know these switch packs can be temperamental through lack of use, I believe you can spray electrical cleaner inside to get them to work correctly
Post #431988 21st Mar 2017 8:58pm
mzplcg
Drive by MOTs are definitely the way forward Thumbs Up
Post #431997 21st Mar 2017 9:37pm
Rob99
Driverless cars (Lord Save Us !! Shocked ) will no doubt have a program which will detect any MOT failure and drive straight to the nearest garage and fess up Laughing Laughing 2021 D350 Fifty Edition
2017 4.4 SDV8 Autobiography -
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #432000 21st Mar 2017 9:52pm
Spelunker
Does that mean driverless cars will also go to the nearest police station and hand themselves in if they break any traffic laws?
Cant wait for Traffic Cops 2025 where we will be shown clips of driverless cars carefully evading traffic whilst being carefully chased by driverless traffic cop cars...... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #432005 21st Mar 2017 10:01pm
SKOT
I can imagine a driverless FFRR destroying an entire town because a few drops off water have got into an ECU or it needs a battery reset..... 2006 4.2 SC
Post #432013 21st Mar 2017 10:35pm
It will be for casualty extraction , if the seat can't be moved back and full reclined you cant get the spinal board in to move the casualty . We used to just cut the battery cables but electric seats being so common now the cables must be carefully removed so that they can go back on later the remove the casualty. 2008 MY Supercharged
Post #432027 22nd Mar 2017 1:13am
Spelunker
Wouldn't the seat electrics be disabled by the explosive that cuts the power cable in case of a crash? Are things like seats, windows etc on a separate circuit that isn't disconnected? QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #432095 22nd Mar 2017 5:33pm
Seems a bit strange but I can only assume it's to do with the fact that, without the electrics working, the seat can't be moved? Got - 2017 SDV8 Autobiography in Loire Blue
Post #432096 22nd Mar 2017 5:42pm
dingg1
The seat. MUST be adjustable fore and aft , thats the reason it failed , simple really its so ANY driver can be in proper control ie reach pedals and steering wheel
Post #432102 22nd Mar 2017 5:59pm
I haven't looked at the explosive decoupler in a while but I seem to remember there being a small feed that is left, as by law the locks and seat must still work after an accident . 2008 MY Supercharged
Post #432186 23rd Mar 2017 2:33am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Sorry. Can you provide a quote/evidence for that please?
What if the battery has been destroyed in the collision...
Post #432215 23rd Mar 2017 10:13am
Lukie
what about car's that have been modified for dual purpose such as road legal rally cars with fixed bucket seats ?
what about specially adapted seats for those with disabilities fixed chairs or wheel chair mounts ?
i believe if it's fitted it has to work, remove all the switch from sight and it should pass
(but first try cleaning them)
Post #432378 23rd Mar 2017 10:53pm
