![]() | Home > Technical (L322) > FUEL INJECTION SYSTEM FAILED 14 TIMES |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
ok thanks, so if the in tank is only transferring one side to another, and had or failed i assume if you were at half tank capacity, it would not start again until you filled up? is that correct thinking? i dont recall what the gauge said on the first time is stopped, but i had started with a full tank and had driven about 300 K so would not have been at half tank, also on way back when it started stopping again several times, i was im sure above half tank, but wou |
G62 Member Since: 16 Mar 2017 Location: Bergen Posts: 12 ![]() ![]() ![]() |
No more fuel in RH side of tank means secondary pump sucks air in stead. First a mix of fuel and air. Look at the second page from RAVE that mjdronfield posted, this clearly shows the tank construction. The in-tank pump wich is in the bottom of the combined pump, fuel pick up, and fuel gauge unit shown in the second to last page from mjdronfield.
300 km from full tank means around 35 liters used and well over half tank left. This would indicate it is not the in-tank pump as it only moves fuel from LH to RH tank part just line you state. Have you had ingjector fuel compensation values read/checked with engine at normal operating temp ? An injector can look fine (or dubious) before engine gets hot. If an injector fails intermittantly it could explain engine stelling, but not bubbles in line near filter though. If the new secondary pump stops that would give such symptoms, since it is new I would check the relay (swap it as suggested) and its electrical connections. |
^ Does that mean if you fill the fuel tank the car will drive normally with no air in fuel? |
no all im saying regarding the symptoms is when the engine was left running in the first no dealer garage, they had changed the filter and let it idle for 2 hours, and all was fine then bubbles appeared in the line by the filter and they started small then got bigger and the the engine stopped, so this is i assume what happens every time it cuts out ;
hi guys;
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
If you open the rear fuse compartment the relays are labelled on the list in the fuse box. I think it's the 4th one from the left. The rear seat heater relay is the same type, easiest test is to swap them. No need to buy one, it's a 30 seconds job from unlocking the car!
Hmm, infrequent use and perhaps some bad diesel that could cause screen in in-tank sender/pump unit to be clogged. Would also clogg fuelfilter quickly. There are additives to kill bacteria in diesel to stopp such growth, also good idea to have full tank when in storage for long time.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
It is more than likely to be the in-tank fuel pump that has started to fail. I had the exact same problem just before Christmas, driving along then engine dies with Fuel Inject System error on dash display. Restarted car after a minute and all fine for a short while, then same thing. Kept doing this at random, and I had 1/2 tank of fuel in the car. It was the in-tank pump not working properly, as it is supposed to operate all the time and supplies fuel to a swirl pot from where the secondary pump can take its feed from. The in-tank pump also transfers fuel from side to side within the tank through a siphoning action, but its main function is to feed the secondary pump. If the secondary pump takes in a bit of air because there isn't enough (or any) fuel being supplied to the swirl pot, this air gets passed through to the air filter, which has a pressure sensor on it. If the pressure drops below a set point, the sensor tells the engine ECU, the ECU shuts down the High Pressure Pump to prevent any damage to it and the engine dies.
hi guys
SORRY ANOTHER FORGOTTEN QUESTION
I thought it was in the wiki, but couldn't see it:
great thanks for that info; i assume no 6 being the one im after ?, and guess A and B IS left and right levels;
No 6 is the one. 30 Left and 15 right could indicate partial in-tank pump failure but not conclusively. If left stays steady at 30 while RH goes lower while driving for a while then yes. Typically the pump fails internittently so in the beinging it is not that easy to spot. Looked at min yesterday; 38 & 34 so some liters difference is normal either way.
