Home > Technical (L322) > Towing electrics |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
If nothings working then i'd start with the earth connection as that is common to each light.
19th Mar 2017 5:49pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Possibly it's the trailer electrics rather than the car as it was working before. But if not then check the plugs as a starter for ten. Open them and check the wires are all good before you tackle the car. There is nothing that can't be fixed with a hammer😜😜
19th Mar 2017 7:15pm |
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 134 |
Corrosion of the ground wire/pin in the plug is the most likely cause. 2012 Westminster 4.4 TDV8 |
19th Mar 2017 8:41pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
Have you checked at the plug with a multimeter ?
19th Mar 2017 9:19pm |
