Home > General > New member considering a 4.2 SC Vs 3.6 TDV8 |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Thats because all supercharged L322's have a six speed box ZF's 6HP 26 in the 4.2 and 6HP 28 in the 5.0 and they use cable selectors and the 8 speed in the 4.4 diesel used an electric selector . 2008 MY Supercharged
19th Mar 2017 2:11am |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
Thank you! I'll take one for the team and show my ignorance. |
19th Mar 2017 7:27am |
Mob17 Member Since: 25 Feb 2017 Location: Northampton Posts: 39 |
Cananyone confirm if a 2007 3.6 TDV8 has a DPF? |
19th Mar 2017 9:39am |
Does this post help?
19th Mar 2017 9:53am |
Thanks. Helps a bit as a member says dpf was introduced in 2010 but he's not certain. Might have to ask the LR dealer then
19th Mar 2017 8:52pm |
Is this a fair summary?
25th Mar 2017 7:01am |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 302 |
The tanks are nominally the same size and whilst it will cost slightly more to fill the diesel due to the higher fuel cost per liter it will travel a reasonably distance further on the same fuel. Hence having greater economy.
25th Mar 2017 9:29am |
Fantastic reply. Truly appreciated. Just as I thought diesel it is, I've now changed my mind back to petrol! |
25th Mar 2017 10:25am |
But surely stuff can go wrong on the SC version as well...? Plus the TDV8s are a bit cheaper than the SC, by around £2-3k.
25th Mar 2017 1:41pm |
I guess you're right. The difference of 2-3k is a lot of fuel. It's why I've constantly batted back and forth with diesel vs petrol all the time. One hand you save on fuel with diesel but the potential costs for repairs is higher(?) but then the cost of a supercharged and fuel to boot means they essentially break even? |
25th Mar 2017 2:17pm |
Although things can go wrong on an S/C it's also stuff that can go wrong on a diesel so let's say the electronic hand brake or RSE but they are common to both model. The point im making is there seem to be more things to go wrong on the diesel.
25th Mar 2017 2:39pm |
MarkA Member Since: 15 Feb 2017 Location: West Yorkshire Posts: 35 |
Given the choice and expect mileage, I would get the s/c. Indeed I had a similar choice recently and bought a s/c. Though I did come from a turbo cayenne so felt the diesel would be too much tractor |
25th Mar 2017 3:12pm |
Its a tough one i admit. But for me the £2-3k savings is quite significant.
25th Mar 2017 5:11pm |
Look for in car entertainment. Rear seat screens. Heated and cooled seats. 2 knobs either side of the clock from what I recall. |
25th Mar 2017 5:24pm |
