![]() | Home > In Car Electronics (L322) > Ibus / intravee alteration |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
I wonder if taking a log with the intravee whilst lowering would show up ? No7 - 2003 V8 Vogue |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
as yt I have not had chance (or had my range rover) to look into this, once I have got to read the log i will let you know if anything can be done |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Are you still looking for this? If it wasn't raining I would do it now but will have a look with NavCoder see if I can work out the command when the access switch is pressed |
Does this help at the bottom when I pressed the access button?
