![]() | Home > General > New member considering a 4.2 SC Vs 3.6 TDV8 |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
1. Mine doesn't but I think it depends where it was destined for.
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 ![]() |
I would stick with the 4.2 that is a very nice option. The reason for the sway is there is a lot more wheel travel than an X5. about 10" in the front and 12" or so in the rear and that is for off roading reasons so that the tires can maintain contact with the ground even under undulating surfaces.
jag-rangie Member Since: 16 Feb 2017 Location: Sheffield Posts: 3 ![]() ![]() |
Sounds like your looking at a similar price point/age to where I expect to be looking. Everything I have read and the advice I have had all points to the 4.2s/c. also if I have interpreted the advice correctly that you are better off with the 07 face lift. I assume that when jag took over and changed the mechanicals but kept the interior the same 05/06 that the plastics etc didn't get changed until the face lift. I am not sure on this though.
Mob17 Member Since: 25 Feb 2017 Location: Northampton Posts: 39 ![]() ![]() ![]() |
Thanks. Do a lot of ppl blank the EGR then? Also hoping a UK member can confirm if the UK 3.6 TDV8 has a dpf? |
I'm only aware of one current option to shut down the EGRs, and that it a remap with BAS. Not actually blanked. There is probably others.
I think the TDV8 had a dpf in later years, does anyone know if early TDV8s (06-07) had a dpf? |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Don't get hung up on 420bhp as the 4.2 S/C has 395bhp but weighs twice as much as your car. If you are doing low mileage then get a petrol, mega miles then get a diesel.
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Any good to you?
Out of interest what do we all consider a lot of mileage? For the decider of SC vs TDV8's.....
That's just under 10k a year - petrol time! Alex
Nah to be honest i tried a supercharghed 4.2 and it felt really slow. No offense to anyone on here but i guess i am used to a much much lighter car which as you say will obviously be faster. At the moment the tdv8s are cheaper than the S/C, roughly £3-4k for 2007 models, so im thinking diesel even though i will do less than 10k miles per annum. I would just like some confirmation on the DPF |
Vergil300 Member Since: 14 Jan 2017 Location: Fife Posts: 39 ![]() ![]() |
Supercharged for me.
Thing is the diesel is cheaper at the mo by around £2k. Also power isnt a concern for me for this purchase.
Yeah, they are cheaper to be fair.
