Home > Technical (L322) > spark plug helicoil
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
spark plug helicoil
hi guys old Censored spat out spark plug yesterday taking head threads with it any thoughts or info on subject how to fix in situ with helicoil. which set to use that is long enough to reach plug hole .
Post #431181 14th Mar 2017 2:43pm
happened here,
http://www.fullfatrr.com/forum/topic27309.html?highlight=helicoil ... - .- -.
Post #431182 14th Mar 2017 2:46pm
rik
thanks but not enough info
Post #431200 14th Mar 2017 5:17pm
jonnyboy54321
Whilst I am game to try anything - this is one of the jobs I would get someone in who does it for a living - like a "glow plug man", or "thread doctor", or similar.
Local independent garages may know someone? Some of them sub that type of thing out to avoid ****ing the job up and taking responsibility.
This is my local guy (no good to you but you get the drift)
http://www.threaddoctorservicesltd.co.uk/ 2007 Vogue TDV8 with 255/55/20's fitted
Post #431217 14th Mar 2017 8:46pm
rik
thanks for that will see if someone can do it tried all locals but they are not willing to risk swarth in engine
Post #431236 14th Mar 2017 11:28pm
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Head off job that one.
cylinder head needs to be removed, drilled, tapped and helicoil fitted.
Post #431255 15th Mar 2017 8:52am
rik
head dont need to come off job is not that difficult getting rid of swarf main problem i have studied this over last couple of days and found an insert the best way to go. got a good mechanic coming sat with all the gear so fingers crossed will keep anyone interested posted.
Post #431292 15th Mar 2017 1:48pm
Sandyt
If you can use a time sert they are in my opinion a bit better than Helicoil used them on my p38 very good they are too
Post #431523 17th Mar 2017 7:04pm
holidaychicken
You don't need to snap off a drive tang either if i recall correctly
Post #431530 17th Mar 2017 8:09pm
rik
all good now used insert put lots of grease on router bit caught all the swarff on the bit. used high heat threadlock on insert engine running nice and sweet fingers crossed . time will tell . lesson to be learned dont leave plugs unchanged for 3 years .
Post #431566 18th Mar 2017 1:10pm
Sandyt
Glad it is fixed Thumbs Up
Post #431618 19th Mar 2017 9:34am
