Home > Maintenance & Mods (L322) > brake lines |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Ok , so I've finished the job this afternoon.
12th Mar 2017 7:15pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
12th Mar 2017 10:12pm |
cheers , I'm having a read this morning.
13th Mar 2017 5:21am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1535 |
What causes this on a not very old car? I've never replaced a brake line, even on 50 year old cars. Ron B. VK2OTC
13th Mar 2017 6:16am |
Probably the salt they put down on our roads.
13th Mar 2017 9:52am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
Mine (2012) had corrosion on rear brake pipes at last MOT, treated with waxoyl, but with road salt and off road muck I expect they will need to be replaced before too long. My last 322 needed pipe replacement after about 7 years I think, so the current one is worse. Only Range Rovers since 1988 |
13th Mar 2017 12:07pm |
OK, thanks.
13th Mar 2017 1:05pm |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 |
Just as an aside.... Are the OEM brake pipes made of steel? The reason I ask is that I heard somewhere that in the US they insist on steel brake pipes on any car with ABS braking systems as the pulsating pressure when ABS is activated can cause case hardening of Cunifer pipes.
13th Mar 2017 1:20pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
I believe they are steel yes. I think that some countries ban copper brake lines due to the possibilities of it hardening and splitting causing issues and failure. Not sure if its actually true though! I did mine in kunifer using joe90's excellent guide and cant see them having issues ever again. |
13th Mar 2017 7:38pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8540 |
yep are definitely steel, and cheap as genuine replacements, the money is in the labour. to get them in and out!
13th Mar 2017 7:52pm |
CuNifer is a copper nickel alloy I think so does this also suffer from case hardening as this is my favoured brake pipe material? 2011 4.4 TDV8 Vogue SE
13th Mar 2017 8:42pm |
http://www.brakeconnect.com/cunifer-brake-line
13th Mar 2017 8:46pm |
