Home > Technical (L322) > Privacy Glass or Tint
Stormin
2003 Range Rover HSE Td6 Epsom Green
When I purchased my 2010 Vogue Se, it had tinted rear windows. Which I believed was factory fit.
However today whilst washing the car, I've noticed that the tint has a slight cut in it.
Surely if it had been factory fit this shouldn't have happened.
Would it have had Privacy glass as standard
If not would it be possible to get it replaced by a good vehicle tinting company Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #430947 12th Mar 2017 4:54pm
tints dont normally come as standard...my 2012 westie had aftermarket tints fitted before i collected it and as it happens one window had a cut...
the dealer organised the tinter to come to me and replace the tint...
i would ring a few tinters for a quote.. ... - .- -.
Post #430948 12th Mar 2017 4:57pm
Stormin
Thanks Stan Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #430949 12th Mar 2017 5:00pm
mjdronfield
I think if it's got factory privacy you can't see the heating elements from outside, as the actual glass is tinted. With the aftermarket film, you can, as the film is behind the elements..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #430971 12th Mar 2017 8:07pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Factory fit privacy glass is tinted glass. There is no film. Yours must be after market!
If you go onto vindecoderz.com and punch your VIN in it will give you a spec of the car.
My RR has factory fitted privacy glass and it comes up in the spec as Glazing - Rear Side Privacy Glass [036EX];
Run yours, i suspect you wont have that!
When you see a RR with factory fit and then aftermarket film next to each other it is quite easy to spot. Although factory fit PG was a must have for me (Prefer the look, as you can see the heating elements through it), there is nothing wrong with good quality aftermarket tint film. Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #431000 13th Mar 2017 12:09am
Baltic Blue
http://www.vindecoderz.com/EN/check-lookup/
If you get the original build sheet from the above link it will be listed under glazing. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #431014 13th Mar 2017 9:38am
Stormin
Baltic Blue
Thank you Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #431045 13th Mar 2017 1:28pm
