![]() | Home > Maintenance & Mods (L322) > Canbus Bulb fault |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
Have you installed the box of tricks that sorts the blinking fog lamp out? http://www.powerfuluk.com/vehicles/range-r...-cars.html Yesterday I couldn't spell Engineer... Today I are one!
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
Unnecessary quote removed
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
I have navcoder and could code that for the rear lights but not the front will have a look at the lonk |
I would have thought that but no option on navcoder sadly. If anyone can get ncsexpert working on l322 then we may have luck but no one has I have found so far... |
I'm sure my navcoder read the LCM with front fog lights, as far as I know the front fog light LED conversion is ran by a ballast resistor similar to the indicator one not the circuit used for rear fog light |
won't that get mighty hot being on all the time? |
I would't have thought so, attached to the car with a gap between the ballast and mounting point should keep it cool enough, maybe email simon @powerful see his thoughts ? |
