Home > Maintenance & Mods (L322) > Fuel Gauge erratic |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Wow - this is exactly what I have with mine at the moment - it essentially reads half of what it should be.
27th Feb 2017 11:13am |
Ok - Had a look around - I know how to get to both units but no closer to understanding what might need doing once I get in there.
11th Mar 2017 10:44am |
Well don't you just love Land Rover....
11th Mar 2017 12:19pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Hi comports,
11th Mar 2017 6:49pm |
Ok just found a full diagram - should shed more light. You were only holding the tip of the iceberg! As far as I can tell, the connector you need is at the fuel pump end right at the bottom. Nos. 14-17
11th Mar 2017 6:56pm |
Thank for this - Indeed it was the top of the iceberg....
11th Mar 2017 7:50pm |
No I think it all related to the lower pump...
11th Mar 2017 8:25pm |
Thanks Greg - Just got it... Ash
11th Mar 2017 9:41pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
My gauge is starting to become erratic on my 2008 3.6.
12th Mar 2017 4:14am |
Hi - yes is says cut off the black connector and replace with connectors. It does say which connectors with a PN. They are immersed in the tank / fuel so pretty sure you could find suitable ones.
12th Mar 2017 7:15am |
Update on mine - had it back to dealer to sort several items under warranty.
25th Mar 2017 8:18pm |
FD Member Since: 15 Jan 2017 Location: Bristol Posts: 31 |
I filled my new 08 FF today for the first time since buying it and I noticed two things...
25th Mar 2017 8:50pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
I never let mine get below 1/4 tank reading, but from full it is usually showing about 350 - 375 miles on the trip and takes 70-75 litres to brim it again. It usually shows about 29mpg, but goes up to 32mpg if it includes a couple of decent motorway trips over 100 miles. Range when full usually shows just over 500 miles. Hope this helps. G reg 2.5VM Vogue Portofino red 1991- 1999
25th Mar 2017 9:02pm |
Hi BB, thx - you are getting good range - 500 miles. And that estimate seems realistic too by the sound of it since you are filling at 25%ish. How many miles has yours done?
25th Mar 2017 9:12pm |
