Home > In Car Electronics (L405) > Music File USB Format?? |
w8pmc Member Since: 30 Oct 2016 Location: West Lancashire Posts: 229 |
What's the best format for a USB stick to be used to import Music into the Music Library?
7th Mar 2017 9:25pm |
Lutonboy Member Since: 26 Dec 2016 Location: Bedfordshire Posts: 35 |
I believe the RR will only properly read FAT and FAT32 formatted media devices. So try formatting the USB stick to one of them? |
8th Mar 2017 8:14am |
Thanks, i'll try those 2 formats although i'm sure my 1st attempt was using FAT32.
8th Mar 2017 8:38am |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 |
<------------ i had some USB sticks with FAT32 - some work and some don't - funny thing on the backseats every single stick worked but not in the front.... All my spelling errorz are belong to me!
8th Mar 2017 8:44am |
These ghost files maybe Mac specific. If you copy your music to a freshly formatted USB (as you have been doing from the Mac) but then open the USB on a Windows Machine and ensure you have the "Show Hidden Files" option set in Windows Explorer. You may then see these "Ghost Files" and should be able to delete them from the USB before then importing your remaining music files into the FFRR. It's a bit of a long winded process, but worth a shot perhaps?
8th Mar 2017 4:14pm |
RSK21 Member Since: 12 Feb 2016 Location: Northants/London Posts: 15 |
Paul
8th Mar 2017 7:52pm |
Thanks for the tips but although the USB stick is now readable, other strange things are happening.
8th Mar 2017 10:49pm |
Is it possible it's the USB device that's not fully compatible? They're a couple of years old now but are USB 3.0 & i've 32gb & 64gb.
9th Mar 2017 7:14am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3815 |
I was having problems with music files copied from my Mac onto a USB stick (FAT 32) but as someone has said already the Mac creates files that the car cannot read sometimes causing the music not to play. I deleted the spurious files using a clean eject type program ( Clean my Drive 2) which detected and deleted them before it ejected the device - I now don't have this problem. Geoff |
9th Mar 2017 9:43am |
Thanks, i've got that programme on my Mac so formatted the USB stick in a Windows environment to Fat32, then switched back to my Mac & copied the Albums across & then cleaned the Stick using Clean My Drive.
9th Mar 2017 1:51pm |
Mine is an older system (MY2010) so that might be it but the other thing I always do is delete any files that are not relevant JPGs for example Geoff |
9th Mar 2017 3:14pm |
I'm slowly losing my mind & this car certainly isn't for anyone with even a sniff of OCD.
11th Mar 2017 12:31pm |
i gave up and use my Iphone over Bluetooth or cable. All my spelling errorz are belong to me!
11th Mar 2017 4:01pm |
Would it be worth modifying the ID3 tags of the album music files to make it look like a single album, make identical as it were all the ID3 fields except track title and track number (increment this from 1 to the number of total tracks). Try this at least with your David Guetta album as a test. It looks like the issue is with how the FFRR reads this info, as you can see all the files in file view. |
11th Mar 2017 4:05pm |
