Home > Maintenance & Mods (L322) > TDV8 oil removal
Macca314
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
TDV8 oil removal
[img]http://www.fullfatrr.com/gallery/albums/userpics/18150/normal_image~26.jpeg[/
I took Ajac8's advice after looking last weekend to service my RR. I bought a Draper expert Pnuematic - Manual oil extraction pump for just Unde £100 It's a good big of kit, but the instructions are a total waste of time. They do not even give you a working pressure in order to operate the pump. When I called the help line they told me the lowest pressure it would operate on was 77Psi and maximum pressure 116Psi. I measured the pick up which is 8mm O/D one of the three pick up straws measured 6mm O/D. So the picture shows a 8mm to 6mm reducer job done. The other pickup straws will easily fit into axles or diffs and the one straw is a metal one covered in plastic.
Post #430095 5th Mar 2017 4:04pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Presumable this is only suitable for engines that have a dip stick. They seem to be gradually be going out of fashion. None of our 3 cars has one!
Post #430098 5th Mar 2017 4:57pm
The 4.4 doesn't have a dipstick but does have the tube which you connect the sucky bit too, it's how they do it in the MD! There is nothing that can't be fixed with a hammer😜😜
Post #430103 5th Mar 2017 5:17pm
Macca314
y
Hi it comes with 3 pick up straws.
One is 6mm OD, and about 900mm long
One is 8mm OD, and about 750mm long. This a flexible steel straw coated in plastic. Looks very similar to a piece of curtain wire
One is about 10mm OD and about 300mm long, used for axle oil etc.
You can use it on any engine simply by inserting a straw down the dipstick tube. I am going to try it on my D1 300Tdi next time.
Then I plan to extract the diff oils out of the L322
Like mentioned in the other reply the 4.4L does not have a dipstick, you check the oil on the dash electronically.
Post #430112 5th Mar 2017 5:53pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Hi Macca
Nice to see you went for it. I just used my bog-standard aldi compressor without even thinking about the operating pressure required.
I'm a bit confused tho - mine came with all the stuff you have mentioned but the fitting i used was a flexible clear plastic tube which squeezed over the engine outlet tube. Wonder if Draper have changed the stock fittings.
Either way very useful. I never even thought of using the other fittings for the diffs / TCase etc. I did them the old fashioned way.
Its clear that anything less that 10 litres will simply not do. There was one stage when I was looking at the filling level and worrying it was going to start over flowing!
Be interested to hear how you get on with the D1 dipstick approach as SWMBO and both my lads have 'traditional' oil change cars. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #430488 8th Mar 2017 6:57pm
mpirie
I'm trying to work out where you suck the oil from in the first picture? Rolling Eyes
Post #430497 8th Mar 2017 8:01pm
look at the engine, the pipe is towards the front drivers side, about 9" - 1' back into the engine bay. it has a black plastic cap on it which 1/4 twists and pulls off.
i used my clarke one on my Mrs car which is a conventional pick up. Just pushed the tube down the dipstick tube and pumped, my advice would be to make sure that the oil is warm before you try and hoover it out as it wouldnt work when cold! There is nothing that can't be fixed with a hammer😜😜
Post #430500 8th Mar 2017 8:10pm
mpirie
Got it, perfect !!
Just forward of the filler cap. Bow down
Post #430502 8th Mar 2017 8:20pm
looks like this.....but attached to the car. Whistle There is nothing that can't be fixed with a hammer😜😜
Post #430504 8th Mar 2017 8:26pm
mpirie
Bow down Bow down Bow down
I daren't ask why that one's not connected Whistle
Post #430506 8th Mar 2017 8:30pm
ajac8
Just to correct my earlier comment and to answer Maccas PM - my compressor was not a bog standard ALDI one it was a bog standard SCREWFIX one. Name on the side of the tank is Sumo and the model number is OL195/24 CM1.5UK (first O might be a Q).
1.5hp nothing special but more than man enough for the oil sucking. I've looked on the SF website but that model is no longer there but I'm not surprised as mine is a couple of years old at least. There are reasonably priced 50 litres alternatives tho.
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #430709 10th Mar 2017 4:03pm
