![]() | Home > Maintenance & Mods (L322) > Brembo brake upgrade |
I'm not entirely sure either will fit the early cars. If they do it would only be the 4 pots I suspect. Even those need a minimum 19" wheel to go over them, not the earlier 18's.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
The brakes on my old '02 4.4 FF were fine, so why would you wish to upgrade them other than for the hell of it?
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 384 ![]() ![]() ![]() |
The 4-pot Brembo callipers are about 140mm from mounting point to mounting point and about 98mm from mounting point to wheel clearance. I think they are a direct replacement for the standard callipers onto a standard hub, though I can see that they might not fit the smaller wheels.
timffrr Member Since: 17 Dec 2016 Location: West Sussex Posts: 37 ![]() ![]() |
It's more that the brakes seem to be pretty rubbish on mine. But I wondering if the system could just do with an overhaul rather than replacement. Having just got back from a trip into town and back I've noticed that one of the rear calipers may be binding so that would help explain the |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
i did this conversion on my 2005 td6 4 pots bolt straight on,you have to get the flexi for the brembos also ,it does improve the brakes and look much better |
