Home > Technical (L322) > Forward alert not available /suspension fault max speed
Iwantbutcantget
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Hi
Hope someone can help. I've a 2010 Rr vogue 3.6 which keeps coming up with these errors,since I had the stabilising arm replaced on steering. Not sure if it is a coincidence that this has happened, or is it a possibility that something got damaged when this took place
I've been reading forum and it mentions hoses and compressers as a possible cause, are these local to steering rack or stablizing arm
Regards all
Jason
Post #430041 5th Mar 2017 7:27am
GraemeS
The height sensor is in the vicinity.
Post #430042 5th Mar 2017 7:42am
Iwantbutcantget
Sorry graemes
Post #430044 5th Mar 2017 8:26am
Iwantbutcantget
Would this point to faulty sensor or electrical wiring in that area
Post #430045 5th Mar 2017 8:27am
GraemeS
I would check that the sensor and its wiring looks undisturbed but reading the fault codes would give a better idea of what's not working.
Post #430048 5th Mar 2017 8:41am
Iwantbutcantget
thanks G for that
called out RAC in end and they found nut had come off sensor on lower arm.
Very Happy Very Happy Very Happy
Post #430075 5th Mar 2017 12:16pm
GraemeS
That was a simple fix - nothing broken. I'm intrigued that forward alert was disabled but I suppose that collision avoidance needs the suspension, braking and steering systems to be fully operational.
Post #430133 5th Mar 2017 7:34pm
