Home > Technical (L322) > td6 injector failure? |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
I had the same as you on start up etc and after a while driving the engine started missing slightly. Eventually it got to a point where I removed each injector electrical injector wiring plug and on No4 cylinder there was no difference in tick-over. Belled the wiring out and proved it was the injector as I was getting the correct voltage as the others and also had continuity. Sourced a refurbished injector off Ebay , fitted it and no further smoke , issues etc. |
3rd Mar 2017 1:38am |
javal322 Member Since: 17 Feb 2017 Location: wales Posts: 41 |
on mine the tick over is fine but fuel economy is bad , it smokes and also has a misfire on start up?
3rd Mar 2017 7:26pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
I recently replaced my 6 injectors, no more than 3 hours work if they are not stuck. I did them myself., but it depend on how fast you are on the spanners. |
4th Mar 2017 1:10am |
thanks i think its the first thing ill look at , bloody gearbox problems now aswel ! |
4th Mar 2017 7:12pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Do the injectors first... I thought my TCC was going again... then 2 injectors all but failed, had the lot cleaned and 2 repaired.. and when I went for a drive with the recon injectors installed the TCC problem had vanished
4th Mar 2017 9:53pm |
TCC?? |
4th Mar 2017 10:37pm |
Torque Converter Clutch (lock up un it in the gearbox) Yesterday I couldn't spell Engineer... Today I are one!
5th Mar 2017 9:13am |
ah yeah i know what it is but didnt connect the shorthand to it lol
5th Mar 2017 3:55pm |
Low fluid? dirty filter? Yesterday I couldn't spell Engineer... Today I are one!
5th Mar 2017 5:38pm |
just had a full engine service and a full gear and transfer box service too |
6th Mar 2017 6:13pm |
