Home > Maintenance & Mods (L322) > Suspension pressure
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Suspension pressure
Does anybody know the normal running pressure for the air suspension?
Using the IID live yesterday, It started at about 70, then climbed to 205 over the next 5 minutes; with compressor temp and motor temp rising and then seemed to settle back to 37.
Post #429534 28th Feb 2017 4:38pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Some are 11.8 bar, and others 13.7 but can't remember at the moment what the difference is between the two!
Post #429535 28th Feb 2017 4:49pm
Stacker
VIN 106309 up to is 13.7 bar (199 psi)
VIN 106310 on is 11.8 bar (171 psi)
Post #429537 28th Feb 2017 5:17pm
