Home > General > pros and cons of jag era vs BMW era vehicles |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
It sounds like you've done the relevant research & come to broadly the right conclusion.
16th Feb 2017 1:02pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
I would say it depends if you do all your car repairs yourself or not, an early one is easy to fix, loads being broken and a lot of info out there, the later ones are a bit more complicated, but do tend to be slightly more reliable...
16th Feb 2017 1:17pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
My 2004 4.4 BMW engine developed coolant-related problems and was condemned at about 97,000 miles, having been serviced on schedule with additional 6 monthly oil changes using recommended synthetic oil. I didn't have a problem with corrosion, but the car had been waxoyled before delivery when new. Some panels had paint blistering due to stone chips by 2013. There were plenty of other problems, brakes seizing, brake lines corroding, radiator leak, power steering pump failure, suspension air bag leak, final stage resistor heater failure, wiper failure etc. Nice comfortable and competent car, but there were phases when it was an annoying money pit.
16th Feb 2017 2:40pm |
Markjohns1 Member Since: 17 Jan 2016 Location: Cheadle hulme Posts: 139 |
Personally having owned an 04 bmw vogue and presently an 07 sc ,both petrol. My experience has been dispite the 04 plate having considerably less miles on it,60000 miles when purchased 14 months ago,age related issues arose probably due to irregular use,electrics being a main bug bearer,ds wing mirror packed up quoted £250,electronic stearing column gave up quoted £700.No phone connection / blue tooth quoted between £300 and £500,suspension pump replaced £300.
16th Feb 2017 4:12pm |
Ah yes, mine had steering column and mirror problems too... Only Range Rovers since 1988 |
16th Feb 2017 6:29pm |
Speaking personally I always preferred the lower profile of the facelifted cars. I never really liked the early ones with headlight wipers, they always seemed a bit boxy.
16th Feb 2017 8:01pm |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
I had the same choice a year ago when I was looking and in the end I opted for the 4.2sc, I have had it a year now its converted to LPG and runs great, I have services, new tyres and a seized calliper on the rear, but apart from that has been a great motor, the kids love the RSE makes for a peaceful journey.
17th Feb 2017 9:45am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Simple one for me . . .
17th Feb 2017 10:32am |
jag-rangie Member Since: 16 Feb 2017 Location: Sheffield Posts: 3 |
Thanks for the input, looks like I'll be swapping from one jag s/c with a 6sp ZF box to another implementation of the AJV8 with the same zf 6 sp. When I get round to it I'll miss the xk but definitely need more space. |
20th Feb 2017 5:11pm |
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 |
Covered it in this book: https://www.amazon.co.uk/Cliffs-Unofficial...01MFDOQ7H/
25th Feb 2017 3:11pm |
