![]() | Home > Maintenance & Mods (L322) > Which iidtool ? |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 ![]() ![]() ![]() |
could anyone let me know the best iidtool for a 2012 4.4 Westminster ?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
I think the BlueTooth one is the only one that works with later cars
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3245 ![]() ![]() ![]() |
Presumably you have looked here: https://www.gap-diagnostic.com/products/iidtool/ ?
It will read/clear faults - so helps with diagnosing any problems
great, many thanks....I will have a read through..
With the tool registered to your VIN number you can access the CCF (Car Configuration File). There you have a list of what is in the car showing whether it is activated or not.
ahh, I see now...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
weegie has given you a link to look at ....here it will tell what you can change , Y. O. L. O. . |
I fear that is rather missing the point of why the tool is recommended by users on here. The tweaking of the CCF is pretty much a one off exercise. You set the car up as you want it and that's normally about it. However, as will inevitably happen with a RR ![]() However, if there is a fault identified, it may be one that you can correct yourself with, depending on your level of expertise/inclination, minimum effort and cost. On the other hand, if you don't wish to carry out any work yourself, then it is very useful to have the relevant information to hand before approaching a garage. Personally, I try to do as much work as possible myself and the iiD tool has more than paid for itself in time and money saved. My viewpoint of the iiD. ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
understood, that makes perfect sense...
Got a non BT one that was for our 2007 that might be looking for a good home |
The OP's FF is 2012 like yours. |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1453 ![]() ![]() |
I have the bluetooth version for my 2012 Westie and its a great piece of kit. |
good to hear, and I think you have convinced me, next questions is where to buy from, is it best to obtain direct from that website?
