Home > Technical (L322) > Rear Washer Jet
muddy_v8
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
Rear Washer Jet
Hi Can someone please tell me the routing of the rear washer jet pipe as i have no water coming out, to be fair i cant even see where the jet is??
The motor is spinning fine just no water
Thank you
Post #428680 21st Feb 2017 6:21pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
you need to remove the rear upper trim panel it just pops in but takes a fair bit levering off once off you can see the wiper motor and water hose check there first to see if you have water that far , To access the rear jet theres two ways one which i've not used apparently is to get the wiper blade vertical and then pop it off it's located at the base of the arm pointing to the side ,the other way which gives you loads of room is to remove the rear spoiler by undoing the four nuts then sliding the spoiler towards the rear and up and resting it on the roof L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #428684 21st Feb 2017 6:41pm
miggit
Getting the blade vertical wont help, it'll hinder, as the jet will be at it's closest to the spoiler... Best way is to fist remove the top plastic trim inside the tailgate and check that it's not a blocked nonreturn valve....
If that is OK then remove the 2 bolts that lock the spoiler in place, close the tailgate and pull the spoiler towards the rear of the car and then lift.... it is held on but 2 large keyhole shaped slots... it is very easy to over yank the spoiler and catch it at the back or the fixing... don't panic, just ease it back towards the car giving slight upward pressure.... All of a sudden it will lift up! then you have to do the other side..... After a few goes you'll be proficient in spoiler popping Mr. Green Yesterday I couldn't spell Engineer... Today I are one!
Post #428704 21st Feb 2017 9:33pm
muddy_v8
Ok thanks guys will check that first didn't realise there was a non return valve in there. I had visions of it popped off a joiner half way under the carpet lol
Post #428709 21st Feb 2017 9:53pm
miggit
If it had you'd know about it cos it would be raining inside Shocked Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #428719 21st Feb 2017 10:53pm
muddy_v8
Thumbs Up Thumbs Up Rolling with laughter
Post #428738 22nd Feb 2017 7:14am
jonnyboy54321
This thread reminds me I have a NRV in the garage -must get around to it as Mrs JB always complaining it takes ages to get water flowing.
But may as well replace camera with a better one at the same time Rolling Eyes 2007 Vogue TDV8 with 255/55/20's fitted
Post #428742 22nd Feb 2017 7:42am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Good thread, mine has never worked properly.
Will check the non return valve later in the day and hopefully report back with some better news for all! Thumbs Up
Post #428761 22nd Feb 2017 10:31am
n1cktdv8
When I did mine I don't recall fisting anything Rolling with laughter
Seriously....I removed the trims etc and did mine when I replaced the rear camera. Strip the pipes and motor off. blow all the tubes through with a bike pump and rinse through with hot water, and refit. Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #428777 22nd Feb 2017 12:40pm
Stacker
Fixed mine today!!
One way value was clogged up, and the plastic bit that goes on the end of the wiper with the two jet nozzles was blocked up. Unblocked them all, works fine now!
Does everyones squirt three times? It seems bit excessive to me!
Post #428863 22nd Feb 2017 10:38pm
muddy_v8
Give me 10min and i will go and find out not sure my wife will be too happy waking her up though !! Rolling with laughter
Post #428867 22nd Feb 2017 10:59pm
n1cktdv8
Yeah she normally does...... Whistle Is this where I put the car details and a bit about myself ?........
Post #428868 22nd Feb 2017 11:08pm
