Home > Technical (L322) > strange intermittent noise on motorway at 100kph ( 60MPH) - |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
I also get that noise at about the same speed, I've put it down to wind noise.
19th Feb 2017 7:03am |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 |
I had that on my 2011 and it turned out to be the side vents being a bit loose. 2005 L322 Vogue Gold gone
19th Feb 2017 10:20am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
check and clean the sunroof seals, they can get a bot crusty and cause a noise, my 12 did this when upto about 80 in france, quick check and clean and all was ok.
19th Feb 2017 10:45am |
Cheers nmj, will have a look.
19th Feb 2017 6:39pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
Thanks will have a look at suggestions once this rain stops |
20th Feb 2017 2:48am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
I had two similar noises at different times.
20th Feb 2017 5:11am |
I had this on my L322 a few years back. I had stored one of those 1L bottles of oil and a rag behind the battery and that was causing it. Several good suggestions above. Try the simple stuff first, what you have is air not flowing as LR intended. |
20th Feb 2017 1:35pm |
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 |
Yes, I had a noise caused by a similar problem after having had a new windscreen fitted. The plastic strip down the sides of the windscreen was loose, and I could almost take it off (but couldn't see it bending back when I was driving, obviously). Autoglass came back and fitted new clips. |
20th Feb 2017 2:19pm |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 89 |
Hi
20th Feb 2017 4:32pm |
Wow!!!! Thanks for the info. |
21st Feb 2017 7:07am |
Fatzo Member Since: 11 Nov 2016 Location: Rigny Posts: 82 |
wow! I have it too when on motorway, especially when i put AC on
23rd Jul 2018 9:28pm |
