Home > Technical (L322) > Can someone interpret thise readings please. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Afaik, the live values should range between minus , which is good, up to +2 or 3. Have you any running /starting problems, I ask because cylinders3,5,& 6 on mine show the same as yours, and cylinders 1,2&4 , range between 0,+1 +1.
20th Dec 2016 4:32pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
Hi gregdav, no starting or running problems. |
21st Dec 2016 1:39am |
Hmmm, same as me, except all of your readings appear to be over the limit.
21st Dec 2016 6:01am |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 |
Did you guys get anywhere with this? just checked my injectors with the GAP IID tool and got:
19th Feb 2017 3:22pm |
Not yet ollie, mine is still running ok.
19th Feb 2017 6:34pm |
ok thats interesting, i've put reddex in my fuel recently and not seen any change yet, if it was causing more of a problem I'd have them reconditioned but as everything seems to work ok I don't see the point in spending £££ on reconditioning if nothing goes wrong |
19th Feb 2017 7:13pm |
19th Feb 2017 9:26pm |
I pulled all injectors and had them cleaned and flow tested, $350 AUD and now all is good. Was told not to put additives into fuel as this causes problems , just to buy fuel from high turn over suppliers in future |
19th Feb 2017 11:58pm |
stobbie Member Since: 29 Mar 2018 Location: almelo Posts: 1 |
Hi, sorry to resurrect this old thread, what were the compensation values afterwards? All around 0? |
29th Mar 2018 7:44pm |
