Home > In Car Electronics (L322) > Reversing Camera - Black Screen of death |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Try these!!
17th Feb 2017 6:40pm |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Cheers Chap, some useful advice here SDV8 AB MY 2019
18th Feb 2017 9:50am |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Mine is a 2007 and following the Wiki along with some testing and a voltmeter I fitted an ebay special and its a much better camera than the original !! Is this where I put the car details and a bit about myself ?........ |
18th Feb 2017 11:30am |
Noticed that the camera's on a couple of loan cars I've had (Ewok, Disco Sport) are alot better as well. Decided to give the old girl a bit of a spruce up before investigating further
18th Feb 2017 3:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35439 |
agreed, not only the cameras but the viewing screens are higher resolution.. ... - .- -.
18th Feb 2017 3:13pm |
unfortunately the Range Rover was the flagship in the line up, and it got all the toys long before the rest of the range did.. so the ffrr is a fault finding exercise for the rest of the LR product range... unfortunately LR have a strange philosophy.. if it ain't broke don't fix it... if it is broke fix begrudgingly.. and if it can be improved, save it for another model Yesterday I couldn't spell Engineer... Today I are one!
18th Feb 2017 3:18pm |
Right, checked the camera via the 753 hack and it seems to be defaulting to PAL. When I change to NTSC and go back to the menu and back in again, it defaults back to PAL. Grrr.... Connected up the IID BT and can get to the menu where it says a rear camera is fitted, but not to any meaningful screen where I could change the setting.
18th Feb 2017 4:00pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
Has the camera been changed at some time? It should be NTSC only, not NTSC/PAL or PAL. The symptoms you are describing with the 753 hack when trying to change to NTSC are similar to what happens when an NTSC/PAL or PAL camera have been installed. John
18th Feb 2017 4:21pm |
Pal
18th Feb 2017 4:23pm |
Cheers Chaps, I think a replacement from Fleabay is on the cards. I'll have a closer look tomorrow for anything obviously not right SDV8 AB MY 2019
18th Feb 2017 4:34pm |
No mate, it just decided to stop working....it is a Range Rover after all! SDV8 AB MY 2019 SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
18th Feb 2017 4:35pm |
18th Feb 2017 4:41pm |
I have lost the will to search, having waded through pages of Russian Microcat I now know that there was a change of camera at 6A216969.. but I suspect that was a mounting change.. and then you get to the 2010 section and the 's have changed the part numbers completely
18th Feb 2017 4:43pm |
Cheers for trying to find out Maybe I'll ask Ducky Dan and see if he can get his LR techy chums to clarify SDV8 AB MY 2019
18th Feb 2017 6:02pm |
