Home > Maintenance & Mods (L322) > 2006 Facelift - Headlight Wiring
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Does anyone know the correct wiring for a light upgrade from 2004 to 2006-2009?
I did the conversion myself, though I think I have a problem with the wiring to the headlights. The bi-xenon shutters are engaged all the time unless I disconnect the battery (or remove the plug to the lights). If I disconnect the battery or remove the light plug, I can hear both headlights clicking and see the shutters moving behind the xenon lens.
I find that I'm getting flashed by on-coming drivers even with both lights adjusted all the way down, and I there is no difference in the output of the xenon light between dip and main beam.
These are the all the wiring diagrams I found for the lights, and I know the last 2 are for the 2010 conversion. I used pin 5 from the old 9-way connector to pin 5 on the new 16-way connector (main beam solenoid), though I suspect something is wrong as they are always engaged. Any help?
 Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #428083 17th Feb 2017 10:43am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Check the purple wire, if this has been used for the shutter power the shutter will be lifted all the time as the purple wire is a permanent live from the diagnostic socket for the old lights which will be keeping the shutter powered continually. I had this exact problem and in the end I cut the purple wire and wired the shutter into the main beam supply so when the main beam is on the shutter will be powered
Hope this helps
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #428164 17th Feb 2017 7:45pm
Zebedee
Thanks Matt
I wonder if different years cars have different colour wires? My 2004 model has no purple wire.
What I have found today is all the wiring diagrams I've got are wrong for my car. Pin-5 (white/black wire) from the old connectors should not be connected to pin-5 on the 06 connector as this is permanent +12v and engages the main beam solenoid all the time. This wire is not required.
These wiring diagrams also don't show the difference between n/s and o/s wiring as they are correct only for the n/s wiring. The o/s dip beam is white/blue and the o/s main beam is yellow/blue.
What does get the main beam solenoids working correctly is connecting pin-5 on the 06 connector to the main beam wiring (white/green on n/s and yellow/blue on o/s), so that pin-5 and pin-10 are both connected to the old pin-9 wire.
What also gets the headlight washers working correctly is to install a mini high-pressure headlight pump in the centre hole in the 04 washer reservoir (the pumps are available on ebay for £17 and you'll need the rubber grommet too). The connector needs modifying slightly to remove a rib so the connector fits. Then leave an old headlight wiper arm motor plugged into the connector on the n/s and tuck it in the space behind the headlight light. Hey presto, fully working high pressure headlight washers, which also keeps Mr MOT man happy. Thumbs Up Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #428282 18th Feb 2017 5:38pm
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
I was reading with interest thanks for that I was wondering how to get the washer jets working 👍
Post #428315 18th Feb 2017 11:47pm
