Thanks Mr Spock
The battery is fine and confusingly, I disconnected the trailer electrical connector (which includes a converter for the 13 pin on the trailer to the 7 pin of the RR) and then reconnected the RR battery.
The RR started on the first attempt and settled down without any problems. Turning the steering wheel fully left and then right cleared all the usual warning lights and everything works as it should.
I did find moisture in the 13 pin to 7 pin trailer connector but don't see how this could cause the problems I had.
As it's a sunny and breezy day, I've left the bonnet up, doors open and boot open with the covers to the electrics on either side of the boot removed to possibly dry things out as I thought water must have got into the RR somewhere to cause the issues it had.
David 2002 4.4 V8 with LPG
Zambezi silver
