Home > Technical (L405) > Interior Lights
porkman
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Interior Lights
Every car I've owned up to now has turned the interior lights on when a door is opened.
Yet I can walk up to my 2015 L405 Autobiography and open a door and be greeted with a black cave.
Same thing when going to get out of the vehicle after a drive. Open a door, no interior lights. You have to turn them on yourself. I don't even think it turns on the puddle lights in this case.
I've gone through the menus - stealth mode is not on. Can't see anything else relevant.
Is this a 'feature' I'll just have to live with?
Post #427564 13th Feb 2017 12:46pm
on the L322 you can press the on/off switch for a few seconds [on the front center light cluster] and toggle between lights on or off when the door is opened.... ... - .- -.
Post #427568 13th Feb 2017 1:04pm
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
from the handbook
Front courtesy lamp: Touch the centre of the sensor lens briefly to switch on/off.
To switch automatic illumination on or off, hold your finger on the lens until the lamp flashes.
hope this helps various other LR's this one is still the best
Post #427570 13th Feb 2017 1:17pm
porkman
Yes that really helps thanks. Certainly a case of RTFM for me.
Someone must have been set it that way at some point as I can't believe OFF would be default.
Post #427573 13th Feb 2017 1:36pm
caymanblack
porkman i can't believe you thought the l405 interior lights worked this way. Laughing
Post #427577 13th Feb 2017 2:24pm
porkman
Why's that then? I'm not familiar with RRs before this one.
Post #427830 15th Feb 2017 9:21am
w8pmc
United Kingdom 2016 Range Rover Autobiography TDV6 Carpathian Grey
I'd not worry, i too have never owned anything from JLR so i'm fully expecting to be sat in it the day of collection & not having a clue how everything works. Total opposite of BMW or Audi where my lever of comfort with the gadgets is high & therefore becomes intuitive.
Post #427837 15th Feb 2017 9:41am
