Home > Maintenance & Mods (L322) > Steering Telescope partial failure
smudge68
United Kingdom 2012 Range Rover Vogue TDV8 Zambezi Silver
Hoping someone can point me in the right direction - MY12 4.4V8TD and the steering column telescope will not extend the steering wheel (away from the dash). It goes up and down and will pull back in towards the dash.
The IID shows B12AA-62 (2F) Steering column telescope sensor B - Algorithm based failure - signal compare failure and also B12A9-62 (2F) Steering column tilt sensor B - Algorithm based failure - signal compare failure.
I've done quite a bit of searching and can see there were many issues with the motors on the early models but can't find any reference to this kind of problem. I'm pretty sure the motor is not operating so don't think it is that!
Post #427461 12th Feb 2017 4:58pm
TomC-RRV8
Don't know if you got anywhere with this I too have this and am taking the collumn apart this afternoon and will let you know if I have any joy! Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #669017 13th Jul 2023 10:50am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
I've had the same issue since I got my car. Doesn't cause me a problem, but interested to see if there's a relatively easy fix. Thumbs Up The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #669056 13th Jul 2023 6:04pm
