![]() | Home > Maintenance & Mods (L322) > Turbo actuator access |
Bantam Member Since: 20 Feb 2012 Location: Cheshire Posts: 27 ![]() ![]() |
Hi There, I have no first hand experience of this, however, mine is booked in next week to do just this job. Also a 2007 TDV8
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Thanks for that. Kinda makes sense.
Just did a bit of searching & here's what I found :
Dang!
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Having done this job myself, I can confirm it is possible to free the actuator arm , but it is not easy. Be prepared for lots of frustration trying to hook the arm. 56 TDV8 Vogue SE
Ok Andy, many thanks.
Finally some success.
barose Member Since: 30 Jan 2017 Location: Peterborough Posts: 2 ![]() ![]() ![]() |
I have the restricted performance warning come up too. There is no discernible reduction in performance at all. I took it to an independent specialist who scanned the vehicle. I watched while he checked most items. From the screen I could see the actuators were moving in unison as he revved the engine. The EGR valves were working well too. There seems to be nothing wrong except the red triangle and the message on starting. He also cleared the code but it reset at higher revs. I am to take it in for further examination but can anyone see what could be amiss here. |
Well spent a couple of hours under the car today - yes, the actuator is hard to find on passenger side !
Took the L322 to an Indy in Peterborough (Bishops 4x4). They figured out it was a stuck secondary actuator. They freed it up and charged me for a very reasonable one hours labour. They advised me to from time to time to get the revs above 3000 as that is when the secondary actuator cuts in. Apparently my sedentary style of driving could cause this actuator to seize over time. |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
A few pics or video showing positions would be good 👍 _____________________________________________________
I looked at getting a few pics when I was looking at mine, but without a ramp, I would suggest its practically impossible to get a decent photo.
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
Just lubricated the drivers side one via wheel arch when changing pads. so took a pic of where to go:
Does anyone know the full range of motion of the actuators in the test cycle at start up? And do both travel the same way ie I can easily see the drivers side one and the arm goes from horizontal to vertical and vice versa a few times at test. But theres talk of pulling the passenger side one downwards with a wire from horizontal. I can hook it but feel theres no way it will go down from horizontal but then you aren't exactly pulling downwards as you are accessing it from behind. I have the dreaded restricted performance message even though it feels the same!
