Home > Technical (L322) > Brake lights on and key won't turn.
RLV
04 l322 v8 petrol. Brake lights came on while parked up. Went into car and key won't turn. Tried the fuse 18 and column plug trick but doesn.t make any difference. Only solution is to disconnect battery overnight. Connect up and it will start and run as many times as you like. Lock it and fault returns after about 2 hours. Looks like I'll need to disconnect the battery every day now when I get to work and stick it back on when I go home. Anybody seen this before?
Post #427340 11th Feb 2017 10:08pm
faulty brake switch?
i'm sure there's something re this on the forum, have a search Wink ... - .- -.
Post #427342 11th Feb 2017 10:14pm
RLV
Just one more symptom. If I leave it sitting for a couple of hours in the fa ult condition with brake lights on the alarm will go off.
Post #427349 11th Feb 2017 11:15pm
could also be a wet or faulty LCM [light control module] which is behind the bonnet pull panel.... ... - .- -.
Post #427351 11th Feb 2017 11:19pm
