Home > Technical (L322) > L322 TD6 alternator output?
phillips321
United Kingdom 2003 Range Rover HSE Td6 Galway Green
hi guys,
I keep getting a flat battery. I believe my battery isn't get charged up properly by the alternator as when idling it's inly 13v (measured using a multimeter).
What should it be outputting, and is this a job i can do at home or is it a garage job?
Thanks
Post #426900 8th Feb 2017 4:21pm
14.2v+
Yes, you can do it at home, with the right tools. Best to remove the radiator for access and removal of alternator. .
Post #426923 8th Feb 2017 5:29pm
andygts
Don't go buying a new alternator either, it will only be the voltage regualtor thats failing and they cost around £20 delivered.
Simple to fit, if you can get the alternator off then you are more than capable of replacing the reg, infact if the rear of the alternator is accessible you may be able to do it in situe. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #426962 8th Feb 2017 8:55pm
