Home > Maintenance & Mods (L322) > Splash guard
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Splash guard
How easy is it to remove the rear splashguard on the range Rover my offside rear has gone porous the retaining pins for the rear shoes have come through so im replacing The rear sheild just wondering how is the job and has anyone else done in the job
Post #426910 8th Feb 2017 4:55pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Haven't done the job myself, but to do it by the book, it's a hub off job.
there is a write up on here somewhere, chap cut his in two, can't remember if he welded a piece of steel on two edges, then bolted the two halves together, but it's a pita.
if your backplate isn't too bad, there is another write up in wiki to strengthen the part where the pins go through, I have done this on mine.
have a search in the wiki, top right of page on here.
greg.
Post #426960 8th Feb 2017 8:46pm
andygts
Depending how far gone the splash guard is you can get a fair few more years out of them and it saves the hassle and expense.
Order a Mk3 ford fiesta rear brake shoe fitting kit and use the pins, buttons and springs, a washer on the pin at the rear spreards the load even further.
http://www.ebay.co.uk/itm/FORD-FIESTA-MK3-...0879764218
probably find them cheaper but this was first google hit. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #426964 8th Feb 2017 9:05pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I think Greg might be referring to me!
To replace it properly, you have to take the hub etc. Off and my hub nut is literally corroded on! Instead I cut the shield in half, and riveted a small metal strap to it, then a nut and bolt through the other side! You could potentially weld it on but will be a pain to hold and weld together!
You can strengthen it, might be worth a search as Greg said.
Post #426966 8th Feb 2017 9:08pm
Stacker
Here is a picture before painting! Gives you an idea
Post #426967 8th Feb 2017 9:09pm
gregdav
Your the man stacker!
Post #426989 9th Feb 2017 6:26am
Simran0211
Thankyou all I will temporarily remove the shoes and when the weather turns sunnier I think the hub will come off and do The job Bow down
Post #427012 9th Feb 2017 9:34am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Pig of a job to do properly. I just cut mine off and had no problems or rattling since. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #427080 9th Feb 2017 6:09pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Well a big thanks to the Forum and in particular Andtgts .(probably others as well - this thread was the most recent)
Rear brake pins pulled through the back plate yesterday, bought the escort pins as per Andy’s suggestion and fitted them today all sorted and one happy bunny.
This forum is a cracker well done to all that contribute Thumbs Up
ps Is it only me that loses at least the skin of one knuckle when working on a FF!! Rolling with laughter (dam handbrake springs)!!
Cheers
Simon
Post #427887 15th Feb 2017 4:48pm
andygts
glad it worked.
Saves a lot of hassle and expense doesn't it? especially if you can't DIY. Current
Previous
Post #427894 15th Feb 2017 5:28pm
gregdav
This forum is brilliant. Thumbs Up
Post #427914 15th Feb 2017 7:03pm
