![]() | Home > Maintenance & Mods (L322) > Drivers window stuck down at 11pm!!! |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
Press and hold the remote lock button down and hopefully it will shut the window. If it doesn't work, release and press and hold again Good luck............. |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
Had this 175miles away from home |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
If you have an IID tool you can force a raise with that if the switch is broken... |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 ![]() ![]() ![]() |
Thanks for replies,
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
The switches are dead easy to fix. Get the module off the door, and you'll see how they come apart. Clean up with alcohol or switch cleaner and should be fine. There's not much to them. |
update:- Tried battery disconnect, holding remote lock..... nowt!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
put a multimeter on the switch outputs to see if any power is going through.... |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
I had this exact problem, at about the same time in the evening!
Hmmm conflicting opinions re trying a fix on duff switch, do I just bite bullet on a new one, think ill look at old one first tonight. At least got window raised for now, just cant use RR as all door card off!! |
Ah I missed that bit sorry, didn't realise you had got the window up! Here are some pictures of the internals:
Had it to pieces and cleaned the contact pads etc as shown in Pic#1 couldn't see any obviously amiss, reassembled and refitted without door card and tried it, put window down an 1" and it raised WOW thought id fixed it, dropped it lower and NO. right down to bottom and stuck again,(now its raining!) Quick get spare battery and apply 12v to motor plug and up she comes, definitely switch assy, think i'll have buy another as my electrical knowledge has expired with cleaning contact pads !!!
Struggling to locate a new switch, all ones on Fleabay are wrong part No, mine ends with ......303PVA
Dan is away until the 7th that would probably be why!
Update it looks like yours is different to mine, Rhd with powerfold for your VIN is different... might be worth calling your local dealer to find out if that's the latest part number as LR always Superceede parts!
