![]() | Home > Maintenance & Mods (L322) > Flashing sidelights |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 ![]() ![]() ![]() |
Ok - I jumped in and changed the sidelights for leds at the weekend (nice effect) but I notice that when I turn the ignition on they flash alternately. I assume this is the canbus and it does stop when I start the car or if I turn on the lights, but will this fail the mot? QUID FACIUM TIBI
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I've disabled mine tonight and I now miss the disco lights |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
I recently changed my front sidelights and reversing lights for LEDs. They work fine but throw up an error. I take it that the forthcoming MOT will not penalise me, or do I need to put originals back in? Previous cars:
Biffo Member Since: 26 Aug 2016 Location: Wiltshire Posts: 82 ![]() ![]() ![]() |
I've not mastered my iiD yet - is disabling the cold monitoring straightforward ? I've just fitted LED sidelight bulbs and noticed the flashing |
Really easy to do.. go into ccf files and select Lcm and switch cold monitering off on all the lights that are flashing when you put the key in.. takes minutes |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
For those of you who can't find enough dosh to get an IID tool, it is possible to turn off LCM monitoring on BMW Nav cars using NavCoder....
Interesting the comment re error free canbus bulbs not being foolproof - the ones I acquired were advertised as error free, does that mean that we cannot necessarily trust advertisements? Is there a tried and trusted make/supplier that we should use? QUID FACIUM TIBI
All an error free bulb is, is a normal LED with an added resistor to give a similar load to a filament light bulb, the resistor bit can fail and the LED will still work, but the LCM will see it as a failed bulb. I have had an "error free" LED that was fubar'd from the word go |
