Home > Technical (L322) > High beam headlights - is this normal...?
M4TT53
Trying to work out if this is a problem or just how the system works:
When dis-engaging the high beams it looks as though the halogen bulbs immediately turn off but it takes a few seconds before the xenons adjust downward. So you temporarily have more light than normal dipped beam, but not as much as high beam.
Is this normal or something I should e getting looked at?
Cheers
Post #424949 26th Jan 2017 9:48pm
from high beam xenon to dip should be fairly instant , maybe something wrong with the shutters?
Post #424965 26th Jan 2017 10:48pm
billsmith737
England 2009 Range Rover Vogue TDV8 Santorini Black
no mate....thats not right, if you turn on or off high beam you should have instant light switching....something is a miss there.
Post #424975 26th Jan 2017 11:25pm
CS
I notice that when the dipped lights first come on they are brighter for a moment and then settle back to the normal level. I assumed that was a feature of Xenon lights and have not worried about it. Only Range Rovers since 1988
Post #425038 27th Jan 2017 1:45pm
^ tis normal chris.. Thumbs Up
Post #425068 27th Jan 2017 4:28pm
M4TT53
Was indeed the shutters. New headlight unit being fitted by the selling dealer to fix it.
Cheers chaps
Post #425928 1st Feb 2017 11:20pm
