![]() | Home > Technical (L322) > 50 CAN bus error |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Have had my 2004 4.4 petrol in to garage and managed to clear all previous faults except for 50 CAN BUS which is stopping the HDC/ABS/EAS from re-setting. Can't put my new alloys/tyres on as can't lock suspension to raise car.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
cant help you with the error james but you can jack up without locking the suspension, i've done it loads of times. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
You can jack it up and change individual wheels without locking the suspension... I do it all the time, when you restart the engine the suspension will level itself...
i assumed you were jacking one or two wheels at one time james not the whole thing [like to see your garage |
No Stan, was getting my new discs and brakes put on my TD6 and asked if they wouldn't mind swapping the V8 wheels for a consideration. But they have a hoist which should make it quicker adn simpler. sadly not to be so it's a couple of hours grunting adn strianing this weekend.
if the car drives ok , i wouldnt worry about it to much mate.. |
Something crossed my mind when I read your last post.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Did you ever fix this? Did it flash up air suspension inactive sometimes? |
Dan, the prob was the neg pole and connecting wire not being tight enough fit - so a bump could lose you power momentarily. All good since tightening up the battery connections. (Think that was the cause but it was 5 years ago!)
