Home > Maintenance & Mods (L322) > Bring me the head...
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Bring me the head of the wannabe designer/ P poor engineer who put the second sump plug of the TdV8 directly above a crossbar so that it's impossible to get a socket on it and even a spanner is always at a slightly off angle.
What was going on in your pea sized brain ? Of course once it had rounded off, it was mole grips time and a bloke with strong arms than mine.
What are others doing about this problem ?
Post #425672 30th Jan 2017 6:57pm
Sticking with my TD6 Thumbs Up .
Post #425678 30th Jan 2017 7:53pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Don't you suck the oil out the dipstick on those? Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #425737 31st Jan 2017 8:50am
DaveK
I prefer the good old fashioned way of using gravity. Just how much of the sludge at the bottom of the sump will get sucked out ?
Post #425738 31st Jan 2017 9:06am
proser
had no problems on the 3.6 I had Thumbs Up Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #425740 31st Jan 2017 9:22am
nino_nino
DaveK this is what I use for second sump plug, it is ratcheted and has adjustable head. works OK for me.
hope this helps.
Post #425863 1st Feb 2017 1:57pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
3.6 is drain 4.4 is suck or drain..
reminds me of the need to push apart the chassis main rails with a hydraulic jack and drop out the cross member just to access the gearbox filter on a RRC Big Cry 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #425910 1st Feb 2017 7:31pm
