Home > Maintenance & Mods (L322) > 2010 style lights
alistairh
2010 style lights
Hi guys .. just a heads up from anybody who has fitted powerfuls 2010 style rear leds.. I've fitted a set on my car using resistors and ballasts and a set to a friends using the interface box you can buy.. both sets of lights seem to have half the lower part of the fog illuminated? When you press the fog it brightens up hugely.. just wondering if this is normal and they maybe quite aren't the same as the proper landrover ones..no errors or hyper flashing indicators either so wired up correctly..
Post #425431 29th Jan 2017 6:03pm
And it made your FF fall over.... Rolling with laughter Pete
Post #425484 29th Jan 2017 9:30pm
alistairh
Hahahaha I cannot for the life of me get them to post upright! Stan usually saves the day and fixes it.. Laughing
Post #425491 29th Jan 2017 9:44pm
saved the day again.......... Mr. Green
Post #425508 29th Jan 2017 11:10pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
There's a configuration setting that you need to change so that the half fogs are switched off. I had this issue but I cannot remember the exact coding but I believe it was the 'half fog' light or similar.
I have a Faultmate Extreme which can re-code the CCF and the GAP IID tool will also do the same job.
regards
John
Post #425512 29th Jan 2017 11:16pm
alistairh
Brilliant! I have an iid tool there.. @ Stan Thumbs Up thanks (again)! Laughing
Post #425533 30th Jan 2017 5:35am
tb10
Oh, you also might want to switch the 'cold monitoring' off re the lights otherwise you may well have warning bongs (check light bulbs) and / or lights flickering on start up.
Post #425660 30th Jan 2017 6:45pm
alistairh
That's a great help thankyou.. I have a brand new iid tool now so shall get a chance tomorrow evening to do this..
Post #425666 30th Jan 2017 7:19pm
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
Any update on this? I have a 2003 Vogue that I'm going to do the rear lights on. I don't mind some DiY, but would like to know these can be fitted without problems?
Post #428443 19th Feb 2017 9:42pm
alistairh
Iid can't turn the half fog off,'gap confirmed it for me when I couldn't find it.. I managed it with resistors and ballasts I got from powerful uks site.. they give you all the wiring info ect.. only thing is mind and mount the resistors on the metal if you can rather than the light unit as the resistors get hit and could melt them..they look great and are worth the hassle..if I couldn't manage the install it was only costing about £50 for an auto spark to do it..
Post #428449 19th Feb 2017 10:22pm
TDSIX
Looks great!
Post #428453 19th Feb 2017 10:39pm
