Home > Off Topic > Monitored Intruder/Burglar Alarm systems |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
this might be worth considering tim, has network monitoring and you can even watch on your iphone..
17th Dec 2010 8:06am |
igore Member Since: 20 Oct 2010 Location: portsmouth Posts: 118 |
Tim give ADT a call and see what they`ve got to suit you. thats who i would go for. oh and they install it ONE LIFE LIVE IT |
17th Dec 2010 9:57am |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 |
I own a hotel and have full a full CCTV system fitted a few years ago by a bunch of cowboys.
17th Dec 2010 10:06am |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Noooooooooooooooooooooooooooooooo, don't even think of ADT, they're ridiculously overpriced, their service engineers are half-arsed and the standard of work from what I've seen is horrendous. And that's not just me saying that, I've heard it from a few customers of ADT and even from former ADT employees. I actually work in the Alarm and CCTV industry, I'm a partner of the family business and we're into our 25th year of trading. We mainly specialise in alarm systems, but also deal with CCTV, door access and electrical work. We've heard from previous customers of ADT about their annual servicing of systems, we spend between 45mins to an hour checking every single aspect of the system for possible faults, one customer said ADT were in and out in 5 mins and charged 3 times as much as us.
You'll either need a NACOS or SSIAB approved installer, (we're SSAIB by the way) If you get quotes for a system from either, make sure they're installing to grade 2x, that way, it meets the insurance standards. The wirefree system BT offer will be a re-badged version of another manufacturer, usually cheaper quality systems in my experience. There's basically 2 main types of system you can go for, you have the conventional hard wired system or wirefree, (or a combo of both but I'll explain later) Wirefree. Pro's: No cabling to worry about, less disruption during installation, (no carpets to lift, walls to chase etc) no limitations to where equipment is sited, easy to add extra devices at a later date Con's: Most devices are battery powered so will need the batteries changed annually, some systems have battery powered external sounders, some of the cheaper systems require a 'hard wired' sounder, only a handfull of systems meet grade 2 specification. Hard wired. Pro's: No device batteries to change, generally more reliable than wirefree, mainly cheaper to install than wirefree. Manufactures have finally started to think of the aesthetics of the system too, once manufacturer we use for our high end domestic and commercial systems has started to make the remote keypads for the systems in a range of different finishes and the option to surface mount or flush mount the keypad... http://www.texe.com/document.php?docid=384 (pdf file - the black and gunmetal look very classy when fitted) Con's: Longer time needed to install, cabling can't always be hidden, adding extra devices can limited if there is no acces with cables
If I was doing a system design proposal, I wouldn't be quoting for window contacts or inertia shock sensors, basically, for a pretty average run of the mill system, I would advise things like front door to be fitted with a door contact that are on an exit/entry timed zone and PIR's (passive infra red/movement detectors) for the rest of the house as they usually have 90 degrees coverage and up to 15m range, that way the whole room is covered including windows and french doors etc. Plus it saves having cables ran round to each window then fixing devices to the window and door frames. You'll find you will get very little trouble with any new alarm system be it wirefree or hardwired, PIR's are nowhere near as unreliable as they once were, they're basically fit and forget items now. For your situation, you could install either of the following, assuming your garage is detached from the house but not too far away. 1, Hard wired system in the house, and another separate hardwired system for the garage 2, 1 Wirefree system for the house and garage combined 3, Hard wired system in the house with a wirefree receiver unit and wirefree devices in the garage. That way you can have everything on one system which would probably work out alot less than both of the above, plus you would only need to set the 1 system. As for the CCTV, void the likes of a Maplin system, the camera quality might look fine when you're up close to them in the shop, but once fitted, they sometimes haven't got the resolution to produce decent images when it gets dark. Also, some of the IR bullet cameras might sound good on paper with 10-20m IR night vision range, but what people forget is that they're likely to be fitted 4-5m up then angled down, so really, they're pretty pointless, most of the time, it will only light up the reg. plates on your car. In fairness, the kit linked by Scarey does seem ok, but just to let you know, most of the time, we pay more than that for a decent quality DVR alone from one of our wholesalers, basically, you get what you pay for. A customer of mine wanted his existing CCTV replaced by us as he had bought one of the Makro specials for £400 and was suitably unimpressed by it, (it was though!) If you're only wanting a camera system to cover the driveway, I'd recommend something like a decent low light anti-vandal dome camera, a small 4 channel DVR with a 250GB hard drive. That really should suffice. Most decent vandal domes have a very low lux level capability, the ones we supply and fit go as low as 0.0001 lux with a feature called 'sens up' enabled, basically, it digitally brightens up the image so you can see in almost pitch black. The majority of DVR's (digital video recorders) now have LAN connection so you can view them remotely, (in fact, I've just been setting one up for a customer today) The only extra thing you will need is a monitor, a standard TFT computer monitor will do the job no problem as long as the DVR has a VGA monitor connection, they it doesn't, you can buy a BNC to VGA converter which will allow you to use a standard monitor. If you would like any more info, just ask and I'll do my best to offer some guidance. 2006 Mercedes CLS 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
17th Dec 2010 7:41pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
We turn out to a lot of ADT activations. They are always graded as an immediate response (10 min) and we always get there well within that time. Yet to catch anyone on premises though- they're in and out in seconds.
19th Dec 2010 12:13am |
Seepee Member Since: 17 Apr 2007 Location: Derbyshire Dales Posts: 100 |
I've got an ADT Redcare 999 system installed at my business and very happy with it,came out best on price when I asked for quotes,serviced twice a year to get around false alarm issues.
19th Dec 2010 7:57am |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
Whatever alarm you buy make sure you get the engineers code for when you need to remove a panel etc for decorating.
19th Dec 2010 12:00pm |
Redcare & Redcare GSM is fine for commercial systems, but I still say it's overkill for domestic systems, you'd be better off having a digi communicator which essentially does the same job, but is a lot cheaper.
19th Dec 2010 12:03pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
Thanks for the guidance and advice guys some very useful stuff there. Sorry i haven't replied earlier as I dropped and then stood on my wireless dongle that connected me to the local wireless broadband now have to wait for the next boatload of stores etc that will be delivered to the anchorage before I can get back online on my own laptop.... O2 has also stopped my internet roaming on my iPhone as I have reached the 40 pounds limit imposed under EU regs, so borrowed one of my officers' netbook computers for a few minutes 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
20th Dec 2010 8:35am |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Hi Tim, O2 can remove the limit if you ask them to! You may be able to get a roamed data bundle on your Iphone as well. You shouldn't really need a dongle as well, the data plans should be pretty transferrable whether on dongle or phone!
20th Dec 2010 4:05pm |
