Home > Technical (L322) > DAB Radio + Sub Woofer |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
if you pick a national station on the dab then you can listen to it across the dab network...pick a local one then you'll loose it when you go out of range... |
28th Jan 2017 7:19pm |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 |
Thanks, I have chosen national ones and it does the same, not as frequent but you get that crackle, then it goes off...if you wait it comes back but think I would rather use normal FM, appreciate the reply... |
28th Jan 2017 7:30pm |
dab is the same as digital tvs in regards to reception, go in between buildings or drive into a dip and the signal goes... |
28th Jan 2017 7:39pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Regarding the sub woofer, I was convinced mine was on the blink until I moved the fade more rearwards. Some songs the sub is noticeable but others the front speakers seem to take over......depends on how the track was recorded?
28th Jan 2017 7:47pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I discovered recently that my Sub was never connected...ever but you'd never have known... It sounds to me that the sub is running on a very low frequency, that would cause it to not notice as much as you'd expect... try playing some Drum n Bass and see how it goes If that don't make it work noticeably then it's fubar'd Yesterday I couldn't spell Engineer... Today I are one!
29th Jan 2017 12:44am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
I thought my sub woofer wasn't working and also got it checked. Turns out it works differently to older models. It doesn't seem to work for low volumes. Needs a bit of welly to get it going. For'easy listening types like me this is a pain. Always sound tinny.
29th Jan 2017 6:59am |
^ "Needs a bit of welly to get it going."
29th Jan 2017 9:17am |
few things to try there, many thanks for your responses, i will go and annoy the neighbours now....
29th Jan 2017 3:35pm |
